Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
iPhone lcd circuit theory
can any one explain how iphone display circuit theory?
yesterday i got a phone6 no backlight no image. when check lcd connector oxide on image rail. after remove oxide backlight+ image comes.
i want to know why no backlight if image line problem?
Update (01/01/2018)
still no answer.
why if no image no backlight??
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
@refectio @teetopp any idea what might be going on here?
von
Einen Kommentar hinzufügen
1 Antwort
The iPhone 6S has a very sensitive backlight circuit. It doesn't take much more than a misaligned connector while the battery is connected to blow the backlight filter (ferrite bead). If a phone was water damaged, all it takes is a tiny amount to short the adjacent contacts on the LCD connector (PP_LCM_BL_ANODE_CONN & GND) to cause the same effect. You might not even see any after effects of the water other than the red LDI.
The Touch IC on the iPhone 6S, now embedded on the screen assembly, replaces the CUMULUS & MESON IC's from the iPhone 6/6P and include the added Force Touch functionality.They wouldn't normally have anything to do with a screen not producing an image.
As for the LCM_Panic line, it appears to be the same thing as the PMU_TO_PHOTON_ALIVE line from the iPhone 6. They both originate from the PMU and are part of the Display Control Signals going to the screen.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Mohammed Irfan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 353
