Unfortunately, the "Rice" trick is mostly a myth. It does nothing but give you a false since that you are doing something to help your phone.
The damage from water is inside your phone, on the logic board and passing current through it will short out components. The good news is if you can open the phone, disconnect the battery, remove the LCD and Logic board and properly clean it as soon as possible. The shorted components can be replaced (In most cases) getting your phone working again.
There are shields covering about 70 - 80% of the components on the logic board that need to be removed, then give the board a proper ultrasonic cleaning with an electrical parts cleaner. Then give it an alcohol bath in IPA of over 95% (I use 99%). Then you can have the board tested to see which parts were damaged and need replaced.
Time is not on your side due to corrosion...you need to get the board out and properly cleaned ASAP.
Even though the phone can sometimes be fixed, there is no guarantee that it will stay fixed as the damage from water and corrosion tends to start a chain reaction for other damage down the road.
There are several places you can send your phone to that will do this service for you for DATA recovery.
Start by searching for a "Micro-Soldering" Iphone repair near you if you can find one. If you can't, there are several here on Ifixit that offer mail in services like myself, but would have to part with your phone for a week or so to have this done.
Do not attempt to charge it, change charging port or battery or apply power to the phone until you have had it properly cleaned as you could inadvertently cause more damage to the Logic board.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
4
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
6 Kommentare
I also had this problem, but all I had to do was spray some compressed air into the charging port and all was fixed! You can use canned air or a compressor. Hope this helps!
von Mikayla Jane
Hi
I fix these quite a lot and generally if the phone has not been opened but has had water damage recently , there is likely still water inside that is evaporating and then condensing over and over and water is likely getting into the contacts and battery terminals.
It really needs opening to let the air on the dry it out but I have found that often the battery controller at the end of the battery gets shorted out and the battery does not function as intended and tends to not charge.
A charge port might be required to get charging again if the metal contacts are corroded and also a new battery may be needed if after the phone has been dried out it will still not charge.
Beyond this it would then need to have the board cleaned by a trained tech who can remove the magnetic shielding off the board and then carefully go over the board and test and check component level parts .
Water damage can be a phone killer and is the worst thing to get into an electrical device .
von neilwardle2002
After dropping my phone in water, I put it in a bag of rice for 48 hours. That seemed to do the trick and the phone worked fine - until I realized it wouldn't charge. Using the advice above, I used compressed air to blow into and across the charging port. Immediately a tiny chunck of something flew out & it my face. It was hard. A few more sweeps yielded 2 more specs flying out. Now the phone is charging as normal. I'm guessing some rice dust or chaff got into the charging port.
von Judith Robar
I sent an iphone SE (1st gen) through a washing machine. It was off, and completely out of batteries when it went in. I opened it up, and popped off most of the cables, and dried it out for a couple of days. After reassembling and plugging in, it showed the low battery sign, and then the apple sign started flashing on and off. Doesn't seem to be charging though. Not sure what to try now.
von Jamie Orfald-Clarke
My iPhone 6 was being wet in water after coming to my home unfortunately I put my iPhone on Charging since from that my iPhone is not getting on and not getting Charged
von Mohammad Zeeshan
1 weiteren Kommentar anzeigen
