Why is screen only responsive if detached from iPhone 6?
Hello I recently replaced the entire LCD with the metal rear plate as the home button wire needed repair as well. After this repair, the screen doesn’t work when affixed back on the phone, it only works when it’s separated from it, just sitting on top. What could this be? All the lines are absolutely attached.
Ist dies eine gute Frage?
1 Kommentar
I will check disconnect the home screen and reinstall....this is the second screen i replace on this phone from the same vendor. First screen only the corners worked on the screen, this one it only works when its detached from the frame...go figure, I feel like it may be some conductivity thing?
von JavierDiaz4
