micro sd card and sim card for dz09
where can I purchase a sim card and micro sc card for a dz09 smart watch?
Ist dies eine gute Frage?
Menü
Deine Einstellungen
Abbrechen
Verständliche Anleitungen zur Reparatur von AppleWatches, Smartwatches auf Android-Basis und Aktivitäts-Trackern.
Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
Schau dich im Store umHi @fish2018 ,
According to the info from this link the GZDL watch uses a micro SIM card. The caveat is that the watch only supports the 2G network, so you need to get a micro SIM from a network provider that still has a 2G phone network in place. It will not work on the 3G/4G/LTE networks of any service provider
This is from the link above:
Phone Function: Can Be As A Standalone Mobile Phone To Make Phone Calls Including Answering And Dial-Up. Supports Single SIM Card (Micro SIM Card), 2G GSM/GPRS 850/900/1800/1900
Hi Larry Powers,
It is a normal micro SD Card, so it should be available in most places that sell SD Cards.
Here is a video that shows how to install it.
As for the SIM card, which can be installed next to the SD Card, according to the User Guide, the watch only supports 2G - GSM 850/900/1800/1900 MHz.
If 2G is not available in your area it won't work with a 3G SIM card.
Kommentare:
Where do I get these cards for my DZ09 watch
von Larry Powers
Is the phone sim card and watch sim cards the same ones?
von Melynda
Hi @sunshinelady ,
Maybe. It depends what size SIM card you have in your phone. They all work the same it is just the physical size can be different
There are 3 sizes for SIM cards.
Nano SIM (8.8 x 12.3mm)
Micro SIM (12 x 15mm)
Standard SIM (15 x 25mm)
The watch uses a "micro" SIM card.
Be aware of the caveat though. The watch only supports 2G mobile phone services. If your preferred service provider doesn't have 2G in your area it won't work.
von jayeff
Thank You, very helpful to me. And now of to Office Max to get my Cards.
Hi @ Louise Howarth,
You don’t need to have a SIM card in both.
It may depend on what you want to do.
The watch can function as a “standalone phone” if it has a SIM card installed, BUT it only works on 2G mobile phone networks. If your preferred service provider doesn’t have a 2G network in your area (or there are none at all) it won’t work as a standalone phone or be able to connect to the internet etc via the mobile phone network.
If your mobile phone is connected to a 3G (or later generation) network then the watch can be used to make/receive calls via a Bluetooth connection with your mobile phone’s network connection. The watch doesn’t need to have a SIM card.
Here’s a link to the user manual which may be of further help.
Kommentare:
So I can't use it to send or receive calls if there no sim card in it
von Louise Howarth
Hi,
Yes you can, if you connect it to your phone via BT. Remember though that there is a distance limit when using BT. It is approximately a maximum of 10 metres (30') between paired devices
See the user guide how to do this
von jayeff
Letzte 24 Stunden: 34
Letzte 7 Tage: 216
Letzte 30 Tage: 1,115
Insgesamt: 22,450
i have the same problem, where can i purchase a memory card for a dz09 smart phone
von joleta c hicks
Just ordered a smart watch and it didn’t come with Sim card where can I get one ?
von Jenna
Hi @thejenna ,
What is the make and model number of the watch
If the watch is a DZ09 then the answer to your question is provided in the Most Helpful Answer box below.
Did you not read the comment about the SIM card size and the fact that the phone service provider must have a 2G network for it to work?
If there are no phone service providers with a 2G network in your area then the watch cannot work as a phone.
von jayeff
Where can I go to get a Sim card and micro for it
von Betty White
I want a Sim card for my smart watch
von Betty White
11 Weitere Kommentare anzeigen
