Zum Hauptinhalt wechseln
Die im April 2011 veröffentlichte D5100 löst die D5000 als eine der beliebten DSLR-Kameras für Konsumenten von Nikon ab. Sie verfügt über ein austauschbares Nikon-F-Bajonett-Objektiv.
Error “press shutter release button again”
Can I repair shutter release button error?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Hello, can this fix work for Nikon d5200?
von Teilen
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
I just had a similar problem on my D5100 and was advised to send it back for repair. After comparing mine side by side to another at a camera shop, (remove lens and with camera on press shutter release button) the lower right corner of the mirror was binding with the stop. We were able to GENTLY pry the lower right corner of the mirror away from the stop (from the right, not underneath) and now it is functioning flawlessly.
War diese Antwort hilfreich?
Bewertung 7
9 Kommentare:
THANK YOU SOOOO MUCH!!! That was the problem. Works perfectly again
von Teilen
Wow such an easy fix I had just put the camera on a shelf for 2 years found this and I have the camera back! Thank you so much I am sooo happy!
von Teilen
Thank you very much your answer. You saved my lots of times. Thanks again buddy.
von Teilen
You're a lifesaver, thank you very much. I was seeing big $$$ signs to get it fixed. Such an easy fix if you are very careful
von Teilen
you are savior.. after 2 years I already got the answer.. Thanks to google too..
von Teilen
4 weitere Kommentare anzeigen
What if it’s doing the similar to myD5200 and it’s not the corner of the mirror sticking?
Bewertung 0
3 Kommentare:
I had the same error message on my nikon d5600 and I have managed to fix it by using an external flash > I've simply attached an external flash to the body, turned the camera and the flash on and suddenly everything was working again. I shot some pictures and removed the flash. The error message disappeared and the shutter release button works again as well. I hope this helps for you :)
von Teilen
Mine is d5200 having the same type of problem but in my case the mirror isn't moving only the left side lever is moving. Any solution please
von Teilen
@remo1098 I have the same issue... there is a slight clicking sound but the mirror is not moving only the left lever... found any solution?
von Teilen
Error press shutter release button again
Bewertung 0
Antwort hinzufügen
Jack wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 79
Insgesamt: 20,156
