Use a 5c or 5S battery temporarily for data recovery
Is it possible to use a 5c or 5S battery temporarily to recover data off a iPhone SE? I have no problem hard wiring it if needed instead of using the battery connector
Ist dies eine gute Frage?
Sure! The connectors don't match but it's still the same output voltage; just solder some small jumper wires. Double check with a voltmeter to insure you have the polarity right.
Another alternative is to use a DC power supply if you have access to one.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 44
1 Kommentar
I do have access to a DC power supply. All I need is +/-? Not the gas gauge or anything attached?
von jjones0377
