Panasonic TH-L42ET60A TV has sound but no picture
TV has no picture, but has sound. When tv is turned on it has a faint light to it (appears to be LED backlight). Have taken rear panel off and connections look fine and has no blown fuses. When TV is turned on has solid green LED illumintaed. Any suggestions?
Update (12/03/2017)
Have looked at all boards and checked fuses and are ok, all connections seem fine and nothing seems to be overly hot when tv is turned on (see pictures)
Update (12/03/2017)
The fuse is intact, can you elaborate by what you mean about checking pins 1-5 on connector 1?
Ist dies eine gute Frage?
6 Kommentare
how ken problam this solution
von Alex Thilak
Hi Team,
I have a Panasonic TV screen lights ON but, no sound and pictures
von Michael Tolasi
Hi @michaeltolasi
What is the model number of the TV?
Can you see the logo/menu screens at all?
von jayeff
Hello I am facing the same issue. TV is less then 1 year and the problem is coming frequent.
Suddenly picture goes off only sounds are playing. After switch of and on again it's running smoothly. Is it a problem? Or there is some special feature?
Thanks
Please help
falguni.roy1@gmail.com
von Falguni Roy
Hi,
If the TV is less than 1 year old, it should be covered by the manufacturer's warranty.
Consult the warranty statement that should be with the documentation that came with the TV (or maybe it's in the User manual) as to what to do to make a claim for a manufacturer's warranty repair or replacement.
von jayeff
1 weiteren Kommentar anzeigen
