Zum Hauptinhalt wechseln
Das Intel Desktop Board D945PSN unterstützt den 2005 veröffentlichten LGA775-Anschluss.
Windows can't load correctly
HP Pavillion 23-HO56 All-in-One Desktop PC series,
My All-in-one PC fell from the table top and the glass screen is shattered, though the display is not affected. The main challenge now is that when powered, automatic repair runs and finally displays 'Windows couldn't load correctly' How can I fix this?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi!
You should try creating a bootable Windows drive and running Diagnostics or "Startup Repair" from there.
Also, your Hard drive might have taken a hit which is why it could be malfunctioning. If you can't log in to Windows after you try a bootable drive that's most likely the cause and you will need a new drive.
War diese Antwort hilfreich?
Bewertung 1
No signal, Bata raha Hai
Bewertung 0
Antwort hinzufügen
Ukan Anobo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 45
Insgesamt: 1,025
