I had a similar problem on my Xiaomi Mi Mix 2 with a blinking white led after the battery has totally discharged.
Here's how I fixed it:
1. Try plugging into different chargers:
Fast charger
Slow charger
Computer USB
2. Charge for a few hours to 1/2 day until screen flashes and/or you see the boot screen looping
3. Leave charging over night or 1/2 day (this will slowly charge up the battery)
4. If the phone still does not fully boot then:
a. Put phone in oven (remove any accessories including case) on LOW, e.g. 250F, 120C for 2 mins
b. Turn OFF oven, then wait 15 mins for phone to cool down
c. Plug in phone and power ON
NOTE: phone showed 60% charge when it finally powered ON, after the oven trick, so it is unclear whether the final problem was battery related or something else?
Good luck!
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
0
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
3 Kommentare
and i have this problem with mi max2
von Hadi Max
Like I later learnt, it's probably a crashed motherboard. Only thing to do is get anew phone or a new motherboard. I got the motherboard and installed it, phone has been running smoothly since then.
von Francis O
brother thanks but now the fastboot is coming but i cant unlock the phone. i try to unlock with MI unlock but it cant and told me current account not bound. how can i do? my phone cant turn on and i cant go to setting
von Hadi Max
