Zum Hauptinhalt wechseln
Model A1224 / Mitte 2007 und Anfang 2008 / 2, 2.4, oder 2.66 GHz Core 2 Duo Prozessor
659 Fragen Alle anzeigen
Tearing apart my iMac 20" system to replace graphics card
I need to replace my graphics card.
We are stuck at pulling out the plug to the on/off button from the logic board. We can’t get it disconnected.
Aside from it hurting fingers. My husband tried to disconnect it & he said it is in there way to tight. He thought about pliers, but is afraid they may hurt something. He said there’s got to be a tool that can be used to pull it apart.
The spudger & prying tool are too weak, I’ve tried it. They break or tear. Any suggestions on a tool that can be used?
It’s on a table covered with a towel. I’m worried my cat will jump up there. Not that he will deliberately hurt something, but that he may consider it a great spot to nap. He’s 16 lbs of muscle & not careful!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
If the connector won't split apart the only other option is to carefully mark the cable wires (polarity) and cut them making sure you have enough length so you can solder them back with some shrink tubing covering the splice.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
ladycerridwyn wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 41
