Zum Hauptinhalt wechseln
Das erste Modell des iPhone, Modell A1203 mit 4, 8 oder 16 GB Kapazität und einer Aluminiumrückseite. Die Reparatur erfordert erhebliches Hebeln und möglicherweise auch Löten. Diese Seite soll Nutzer:innen bei der Fehlersuche und -behebung helfen und sie bei der Suche nach Hilfe für das iPhone 2G unterstützen.
224 Fragen Alle anzeigen
How to repair broken LCD Screen
Amigos,
LCD screen of my iPhone(A1203 - 1st Gen) is damaged and I need a new one.
I can't locate this info on ifixit.com. Any pointers?
cheers,
Rocky
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Here's how to fix it: iPhone 1. Generation Displayeinheit austauschen
The part is not cheap, I'd do a lot of searching for prices before trying to fix it: http://www.idemigods.com/iPhone_1st_Gen_...
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
http://www.rapidrepair.com/shop/4120-lcd... little cheaper and the least expensive on ebay at http://cgi.ebay.com/iPhone-1st-Gen-2G-LC... so it pays off to shop around :) good luck
von
I've done this repair and it's a lot of work. You have to open the iPhone from the back to replace it. While you can buy the whole display assembly I did it with just purchasing the touch digitizer. It's a little more difficult but will save you $40. Shop around on eBay for the touch screen. Don't buy from China on this one. Read through the step by step on how to remove the display assembly and then check out youtube videos on how to separate the touch digitizer from the main display assembly. You're gonna need a hair dryer and one of the plastic pry tools. You can do it. I did that as the first thing I'd ever done on an iPhone. Take it slow when disassembling don't rush things. If something isn't coming easy don't pull harder. I did and tore a ribbon cable. Best of luck!
Bewertung 2
if it still works it not the lcd its the frunt plate
Bewertung 0
Antwort hinzufügen
Rakesh wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 9,252
