Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Model A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac13,2
260 Fragen Alle anzeigen
Won’t start after electrical problems
Hi,
I’ve got an iMac 27” late 2012 which came to me after a company messed with the electric in my clients home. He blew the circuits and after that the iMac is really dead. They got another and I would like to try to bring the old one alive again for my own personal use.
Can anyone tell me if there is a possibility that there is more broken then just the PSU?
I know with pc’s that even the CPU can blow out with electrical peaks. Is this the same with Apple products or are they better protected?
I don’t want to buy a new PSU and then find out that things like the CPU or screen are also broken.
Anyone an idea about this? Even if you say: get rid of that iMac, is an answer for me if you can give me a good reason why.
Thanks in advance
Nathalie
Ist dies eine gute Frage?
Bewertung 0
Kommentare:
What are the diagnostic LEDs telling you?
von
Which diagnostics LEDs? I’ve never seen any in an iMac. Did see them on a mainboard for a pc but never in a Mac.
von
From 2008/2009 onward iMac’s have had them. The 2011 and older systems have them located just to the right of the memory slots. Sometimes covered with tape or just below the lip of the frame.
With the newer ‘Thin Series’ they are located at the bottom left edge of the logic board near the power supply.
von
Einen Kommentar hinzufügen
iPhone LCD Display Fix Kits
Die Budgetoption, abgedeckt durch unsere lebenslange Garantie.
Kits kaufen
Reduziere die Reparaturkosten, nicht die Qualität.
Kits kaufen
3 Antworten
Hilfreichste Antwort
Hi @eaglepanther, well, IMO it is about luck, sometimes, during this case, couple of things can fail.
e.g. hard disk, mainboard, etc
rarely heard about cpu, rams but as mentioned, unless you have another set / close system, which you can test the other components out.
if you have some electronics background..... you can take out the power supply and measure the output voltages. confirm with the part number of the power supply, and google for the pin out schematics. e.g. 12V, 5V, etc
there are several youtube video tutorials, showing on how it can be done to check the power supply.
War diese Antwort hilfreich?
Bewertung 1
Kommentare:
I’ve put another HDD in (the old one is in use by the old owner so that didn’t break down).
After the electrical peak the iMac worked a little bit before dying completely.
I’ll try to test the PSU but I’m pretty sure it’s fried.
Do you know if I can test the other components without putting parts in another iMac (which I don’t have, not that type, only older).
von
I would say follow the basics like resetting the SMC.
https://support.apple.com/en-us/HT201295
On older models there used to be LEDS on the Main Board the showed if it was getting power and such but you probably want to give it a visual inspection to make sure there are no obvious faults like burnt spots.
Unfortunately you will probably need a Multimeter, the Schematics for the iMac and knowledge of how to read Schematics. Worst case scenario is the that the CPU or Graphics card. If its the PSU then that is a relatively easy swap but if there is a component on the Main Logic board that died then you would more than likely need good Microsoldering skills as component level repair is not so easy.
Bewertung 0
Kommentare:
Sadly I can’t reset the SMC because the iMac won’t start at all. It’s really dead.
I do have a multimeter but never used it but I will try.
von
Resetting the SMC is as simple as
Unplug the power cord.
Wait 15 seconds.
Plug the power cord back in.
Wait five seconds, then press the power button to turn on your Mac.
If there is no life then it didn't work.
von
@thadlee - If the system won’t start a SMC reset is not going to change anything.
Desktops & Laptops (MacBook systems) are different when it comes to troubleshooting and diagnosing problems.
von
Did you find the diagnostic LED’s?
Bewertung 0
Antwort hinzufügen
Nathalie Spoor wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 98
