Zum Hauptinhalt wechseln
Zweite Generation, herausgekommen im November 2011.
Powers on but won't stay on or doesn't power up at all.
Powers on intermittently but powers off by itself. Confirmed good battery and A/C power supply. Switch, motherboard?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Using the Sony battery, it will power up but will not power down with the switch, nor will it power back up. Screen goes blank. If I release the battery and reinsert it it will power up. I doesn't matter if I use the battery or A/C power adapter. I'm leaning towards motherboard although I have my questions about the On/Off switch.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Check the internal battery contacts and clean with qtip and alcohol...I have cured a similar problem because oil contaminated the contacts.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Thanks but I looked at those. I'm guessing the problem is with the logic board. I will post on here if that is the solution. Thank you.
von
Okay..it does sound more like a dry joint leading from battery unit to switch or board....forgot to mention...I take it you are using the bonafide battery from Sony?Because they have a chip inside and third party batteries will power up and the camera software detects they are not Sony and so switch off the camera.
von
Antwort hinzufügen
HITGFRY wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 571
