Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Das Modell A1238 / 80, 120 oder 160 GB Festplatte / schwarzes oder silbernes Metallfrontteil
1018 Fragen Alle anzeigen
Why won’t my new battery charge?
I installed my new battery in my iPod 7th Gen Classic. I plug it in and it won’t charge. It just has the charge it came with new.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Usually battery replacing are done by professionals, but I'm not one to judge there, can you check if everything's connected properly since you installed it?
Also try different adapters and cables if you're able to.
War diese Antwort hilfreich?
Bewertung 0
Kommentare:
@lenafox professionals aren't the only ones! ifixit says at the bottom of the community guidelines "Remember: It's might be easier to fix things when you've gone through five years of service training. But it's not necessary. Amateurs have changed the world!" scroll all the way to the bottom of Community Guidelines and you can see examples. on the unrelated note, good job on iFixit! I usually check on new users and I've seen you improving! keep up the good work! =)
von
I guess that's true haha, sorry I didn't know, I'm still bit new to iFixIt
But everyone can still make mistakes, of course we can all do these things ourselves (Even I). Apologies for forgetting the Community Guidelines
von
@dconsmack here is the guide for it iPod Classic Akku ersetzen and double check your work. always double check the dock connector. Check for bend, broken or corroded pins as well as debris. Try a new cable and try a different charger. It is possible that you have a bad battery. Try to replace it once more. It is also possible that you are having issues with the actual battery connector. It has the tendency to break of that board. Carefully double check on that. Anything past this will be related to the charging circuit on the board and schematics are not available. It would put you in the having to replace the board category.
Bewertung 0
Does the device show the Charge Indicator in the battery?
If Yes the problem is that you could have been given a defective battery, I would first check the connection to make sure It's properly making contact. If so the problem maybe the terminal for the battery itself may have been damaged, the post is fragile and It could be damaged when pulling the latch to release the battery connector. If that checks out then you have a defective battery
If It does not the issue is with the 30 pin connector itself. That connector often has a lot of lint that may need to be cleaned out. Using a very thin tool like and iSesamo and a pick can help, be careful since you don't want to damage the pins. If It's clean then the port itself is bad and needs to be replaced, that involves micro soldering.
My best advice is to buy a known good similar device if it happens to be anything involving the board, if files are an important factor just use a zip drive reader to pull files out of the device.
Bewertung 0
Antwort hinzufügen
Todd Waetzig wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 4
Letzten 7 Tage: 9
Letzten 30 Tage: 33
Insgesamt: 963
