The Gateway-600YG2 has an Intel® Pentium 4™-M CPU with 512 MB 266 MHz DDR-PC-2100 SDRAM standard. This laptop also has an optional wireless card installed by the factory.
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
1 Kommentar
Hi,
What OS is installed in the laptop?
Have DVDs worked OK before on this laptop?
If not have you got a DVD drive installed or a CD-ROM drive installed? Check the drive's plastic cover to see what it says.
If so have you tried another DVD to see if it works OK?
Do you get sound when the DVD plays?
Does the DVD drive work OK when you insert a data disc, (CD or DVD)?
1 Kommentar
Hi,
von jayeff
