Zum Hauptinhalt wechseln
Veröffentlicht im März 2016. Modell: SM-G930 Versions: G930F (Global); G930FD (Global; Southeast Asia); G930W8 (Canada).
Finding IMEI with FRP lock
hey guys.
Im looking to get the IMEI off of a board i got delivered. but its FRP locked. there are no identifiers on the board itself, and the dial code *#06# doesnt work because emergency caller wont allow it.
Am i missing something as to where that should be recorded? i know iphones have the "i" at the bottom corner, but samsung doesnt appear to have it.
Ist dies eine gute Frage?
Bewertung 7
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Does Download mode or Recovery mode show the IMEI?
Download Mode may show through adb?
War diese Antwort hilfreich?
Bewertung 3
7 Kommentare:
neither of them show the imei. Im currently installing ADB to run through the last suggestion. while im doing that, do you have the command i would use to pull the IMEI through adb?
von
adb shell dumpsys iphonesubinfo
von
i get No device/Emulator found When i try to connect. i Have Google USB drivers installed in my SDK manager.
von
Removed comment.
von
2 weitere Kommentare anzeigen
press volume up, power and home buttons all at same time. While holding down all 3 buttons the screen will start to flash and immediately let up on buttons and hit volume down and the IMEI, SKU and SN will appear on the screen.
Bewertung 1
1 Kommentar:
Should the phone be off or on ?
von
if the battery cover is original it will have the imei at the bottom, hard to see i suggest some kind of led light to shine against it
Bewertung 0
Antwort hinzufügen
Scott wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 59
Insgesamt: 12,267
