Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
Use a drill bit that's about the same diameter as you think the screw thread is, then just drill into it via the screwhead. Eventually it'll 'catch' and you can put the drill into reverse and extract the screw.
1 Kommentar
Have you seen how tiny these screws are???
von Jeremy J Baker
