Zum Hauptinhalt wechseln
Kohler makes the gas powered engines for many different riding mowers & garden tractors both for home owners and professionals.
Engine will run for 2-5 minutes then die
Engine on Kohler powered tractor will start and run for 2-5 minutes then die. It will not crank for 5-10 minutes. After waiting a bit it will crank and then do same. It does this regardless of outside or engine temps. I have run a jump wire to fuel solenoid to rule out the silenoid stopping fuel at float bowl. I've replaced the air filter and checked all fuel lines for crimps. The fuel pump seems to be working also as i can see fuel flow thru the clear housing of fuel filter and it maintains a constant fuel level. I'm stumped.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Take a look at this web site: Kohler Engines See if you can identify the series of your engine and see what the service manual tells you.
War diese Antwort hilfreich?
Bewertung 1
I know this is a very old question but it’s the coil.
Bewertung 0
Try removing/eliminate the fuel filter, sounds like it is vapor locking. If that works, replace it with the small filter that only has a screen in it....it's usually red and is used with lawn mower engines that do not have a fuel pump, but also works if you have a fuel pump. Sometimes those bigger plastic fuel filters will vapor lock after engine runs for few minutes.
Bewertung 0
1 Kommentar:
I had a problem with the gas line being routed to close to the exhaust and fuel was getting to hot in the line and was creating the motor to starve out! Just my personal input from trial and error of trying everything I could think of
von
Antwort hinzufügen
Junior Valentine wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 60
Insgesamt: 3,669
