Zum Hauptinhalt wechseln
For 1992 the Grand Am received new body work and a revised interior. A V6 option returned in the form of the 160 hp 3.3 L 3300 V6. The 2.3 inline four came as either a SOHC or DOHC.
5 Fragen Alle anzeigen
Lights don't work in dash or tail lights
There are no dash board lights (except check engine) no tail lights, brakes and turn signals work. Fog lights don't work either. I replaced fuses interior and under hood, still nothing. Should I replace the relays too? I don't have any other ideas
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi,
Are you sure that it is the check engine light and not the service vehicle light?
Here is a video to explain the difference.
If none of your lights work then you may have a problem with the BCM (Body Control Module) which would have to be checked out by a dealer.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Both check engine and service lights are on. I will have dealer check BCM. From what I gather, this issue is popular one in this make and model. Also, a whole ton of different reasons for this problem. I'll just keep trying, eventually I'll get there
von
Antwort hinzufügen
Heaven Jourdan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 136
