Zum Hauptinhalt wechseln
Das Gerät wurde in 2014 veröffentlicht und hat einen 11,6 Zoll Bildschirm. Das Gerät ist ein 2-in-1 Convertible und hat einen Touchscreen.
How to replace a cracked screen?
Hey! I dropped my HP Pavilion 11-n011na x360 and unfortuantely there are two cracks on the screen, I was wondering how I would find the exact replacement screen as I've seen a few different ones and I'm completely clueless when it comes to this type of thing and how I would go about actually replacing the screen, I haven't seen any guides on the HP site or here.
Thanks!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
Hi try to check this service manual
http://h10032.www1.hp.com/ctg/Manual/c04...
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi @lecollecteur,
The service manual gives instructions regarding the necessary pre-requisite steps and then the procedure on how to remove the LCD screen. (see p.58 in the manual)
On p.15 of the service manual, you'll find the 4 types of LCD screens used for the different variants of this model. To be absolutely sure that you have the correct one for your laptop, the part number will be stamped on the back of your LCD screen. You'll have to dis-assemble the laptop to remove the screen to find out of course.
Once you are satisfied that you have the correct part number, search online using just the part number only, to find suppliers of the part that suit you best.
War diese Antwort hilfreich?
Bewertung 3
Hi try to check this service manual..
Bewertung 2
Antwort hinzufügen
lecollecteur wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 35
Insgesamt: 2,583
