Zum Hauptinhalt wechseln
This is a stainless steel, 4 slice toaster oven. The model number is located on the bottom of the device. It has a single rack height and a removable crumb tray.
10 Fragen Alle anzeigen
Why is my ON light always on even if all the knobs are off?
My toaster is brand new and i used only once. The second time, the ON light kept turned on even though the oven was off. Is there anything I can do to turn it off?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @csiqueirab ,
Don't know your toaster but was wondering if the timer control knob should be at the red arrow position and not at the blue arrow position as shown in the image below. Apologies if you have it already there
(click on image to enlarge for better viewing).
If this is incorrect, I suggest that you contact Black & Decker customer support either for an answer to your problem or if the toaster is faulty what to do to get a manufacturer's warranty repair or replacement.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
It worked! I can't believe I didn't see this feature "always on"! It worked! Thank you very much!
von
Antwort hinzufügen
Camila Siqueira-Boonstra wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 8
Insgesamt: 77
