Zum Hauptinhalt wechseln
Angekündigt im März 2015, erschien das Samsung Galaxy S6 Edge am 10. April 2015, als die Version mit gekrümmtem Bildschirm von Samsung neustem Flaggschiff-Smartphone.
S6 Edge won't charge
Just put new motherboard and charging board on. When I plug in with the phone turned off, a grey battery with a lightning icon appear on the screen then disappear in a few seconds. When I plug in the charger with the phone turned on, there is no lightning symbol on the battery icon indicating it is charging. Tried both soft and factory reset, not working. Anyone got any idea why is this happening and how to fix this?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Why did you put on a new motherboard and charging board? Did it get wet? Mine did, but I didn't think it would really hurt the phone since it was in a case and I initially couldn't even tell it was wet. It still was on and worked okay for a few mins and then I thought using a hair dryer to speed up the drying would be a good thing to do.
After reading, I'm thinking that was not the brightest of ideas on my part. Now I get the white lightning bolt sporadically also when doing a safe reboot or a reset. I can't get a charge at all. I hope someone helps us out soon on this question!
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I'm guessing defective charging port.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Deng Pan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 760
