Zum Hauptinhalt wechseln
Ein kleines Streaminggerät das direkt in die HDMI Buchse am Fernseher gesteckt wird. Es kam 2014 auf den Markt. Die neuere Version kommt mit einer sprachgesteuerten Fernbedienung.
116 Fragen Alle anzeigen
Why won't my power cord go into my firestick?
I took the cord out of the firestick to use the cord to charge something else. When I tried to reconnect the power cord to the firestick, it was as if something was preventing the cord from connecting. The cord connects to my other fire stick devices but not this one. So my power is just a charger cord and my fire stick is essentially useless.
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
My fire stick wire has a short can I use a regular phone charger to replace the wire
von
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
Are you sure you are putting it in correctly? Take a magnifier and a flashlight and look inside the plug hole and make sure its not gotten bent up or it doesn't have anything stuck in there.
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
Worked (safety pin). Thanks.
von
I had this exact same problem. No matter what I did, I couldn't get it to plug in. I took a pin and very GENTLY slid it behind the male connector and lifted up just a little. Voila, plugged right in!!
Bewertung 3
1 Kommentar:
Worked! Thanks!
von
I’m also having that problem. I’ve tried other cords as well but none of them will go in. I’ve looked in the stick and nothing looks bent or any foreign objects. I unplugged the cord from the fire stick because I was having the issue of it saying no signal. Are these two issues connected? Is my fire stick now garbage?
Bewertung 1
2 Kommentare:
Mine has the same problem. The male (center) connector is not centered in the opening and will not slide into the the slot in the power cord end.
von
I had the same problem after moving the TV across the room. I gently rocked the power cord end into the fire stick and it eventually aligned and went all the way in.
von
I could only find a cord that matched it from Amazon, which also is the only thing that works for my Samsung Galaxy 8. I’m not sure WHY they made the cord different, but sure is a pain to find exact replacement (which I found here: https://www.amazon.com/Adapter-Charger-A... )
Bewertung 0
Antwort hinzufügen
Keenan McBride wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 27
Insgesamt: 10,941
