Which thermostat should I buy and how to wire it?
So I have a freezer with a bad thermostat (the contact wont close when it gets hot unless I hit it)
the thing is the thermostat has 4 pins
It works like this
The green light is always on
The red light turns on if the temperature is too high to safely store food
And the yellow light turns on when you hit the fast freeze button(which based on the wiring it just bypasses the thermostat)
I already bought a thermostat and it works but the upper temperature (when the compressor kicks in) is too high and everything melts and after reading the box it says its for 2 door fridges (its a danfoss thermostat)
The issue I have is that I don't know what type of thermostat I should buy and how to wire it back?
Ive checked on Danfoss website and there are many types and models of thermostats (freezer without signal, freezer with signal and freezer with passive signal or something like that)
Any help would be appreciated
The Freezer in question is an electrolux EFUP195YSKG (220 volt version)
Ist dies eine gute Frage?
2 Kommentare
How about the make and model number of your appliance?
von mayer
its an electrolux efup195yskg
220V-50Hz version
von ahjklsf
