Zum Hauptinhalt wechseln
Das LG G Pad 8.3 ist ein Tablet von LG Electronics Inc., das 312 g wiegt, 16 GB Speicher besitzt und über einen 8,3-Zoll-Bildschirm verfügt.
Why won't it shut off?
My g pad is frozen on the secure start up screen. I put in my pattern and it said to shut off and restart to unlock device. But now its frozen. And wont shut down for a hard reset. What do I do?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare
Hi,
Have you tried holding the power button until it force shuts down?
von Teilen
Good morning! And to answer your question, I have held the Power button down for several minutes to no avail.
von Teilen
Thank you for the info. I already done that. I believe that the power button is not working. When I got it apart it looked like it had been poked by something very pointed. I believe it either severed or disconected some wires in the ribbon. I would try to jump start it off the board, but can't find the "ground" and don't want to fry it. I can get a new starter/volume button for about 6 bucks.
von Teilen
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi,
If the tablet is still on, then here is the ifixit LG G Pad 8.3 Akku austauschen guide.
Use the guide to disconnect the battery from the systemboard in the tablet. Once it has turned off, reconnect the battery and start again.
Alternatively wait until the battery has discharged enough for the tablet to shut down then fully recharge the battery before attempting to turn the tablet on again.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
william armstrong wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 17
Letzte 30 Tage: 29
Insgesamt: 1,559
