Please help! Need help Diagnosing/Troubleshooting TV! (Video included)
Video:
Yesterday my TV decided to stop working and I'm having trouble diagnosing the issue.
Here's a video of the issue: https://youtu.be/F8IWaukZyHg
Description:
The TV will work properly for around 30-60 seconds.
Then the sound will briefly slow down before the TV "crashes".
It stops responding to the remote (normally a light below the TV flashes when a remote command is received) and a whining noise can be heard at the rear.
After this happens, unplugging/replugging the TV in will cause the power LED to light, but there's no picture, sound or responses to button presses/remote.
Disconnection from power for 10 minutes or so is the only way to get it to show an image again, followed by the usual crash.
I've opened it up check cables and capacitors but all seems fine.
Thoughts:
Due to the slowing of sound just before it crashes, I feel it may be a lack of sufficient power to the TV, either the fault of the external PSU or the power board in the TV itself.
This is simply based on how other devices react to low power though, I'm not an expert by any means!
If you have any ideas then please let me know!
I'd like to figure out the cause before I start randomly buying replacement parts in an attempt to repair it.
EDIT:
As requested, here are some pictures of the TV's boards.
Inverter board;
Inverter board Caps:
Side Main Board:
Main Board:
TCON:
TV Overview:
Ist dies eine gute Frage?
6 Kommentare
@hellsplumber what model is your TV? Sure looks like a component overheating. You do need to check the caps and IC's on the power supply as well as the main board.
von oldturkey03
@oldturkey03 Thanks for the reply!
The model is the Sony kdl-42w705b.
I ordered a replacement power supply which arrived today, but sadly I'm having the same issue so we can rule that out.
The problem takes under a minute to occur even after sitting overnight in a cold room. Is this still enough time for it to overheat?
I'll look into checking the caps properly.
von HellsPlumber
@hellsplumber post some decent pictures of your boards with your question. That way we can see what you see and can possibly help you out more. Use this guide Bilder zu einer vorhandenen Frage hinzufügen for that
von oldturkey03
@oldturkey03 As requested I've added pictures of each board, hopefully they can be of use!
von HellsPlumber
@hellsplumber did you replace the caps on the LED board? If so, for what reason? If not then they do look like they have been replaced.
von oldturkey03
1 weiteren Kommentar anzeigen
