Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s Plus gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
1041 Fragen Alle anzeigen
iPhone 6s+ keeps clicking on things that I'm not even clicking on?
A few weeks ago I replaced my phone screen along with the battery, and it was working fine for about 2 weeks. I now have the issue of the phone clicking on random stuff by itself. It happens randomly during the day and makes the phone almost impossible to use. The random touches seem to only be occuring in the lower area of the screen, registering touches mostly in the bottom 1 inch of the screen.
Ist dies eine gute Frage?
Bewertung 1
4 Kommentare
Have you put heavy stress on the phone like sitting on it? (sounds like digitizer)
von
ULEES- I occasionally sit on my phone by accident but I dont think that would be the issue since I keep the phone in a case at all times.
von
The pressure of your weight could damage the screen
von
ULEES- is there anyway you know of to verify/test if that would be the problem? or any fixes?
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Hey Brandon, what is possibly happening is the battery could be not properly installed pushing on the display, because what is happening is ghost touch. You may need to try reseating the battery, and reconnecting all of the connections. You should reach out to where you purchased the display from if this doesn't fix the issue.
War diese Antwort hilfreich?
Bewertung 2
5 Kommentare:
thanks for the response Alec. I will give it a try and update after.
von
No problem, I hope all goes well, good luck sir
von
Update: After reseating and being absolutely certain the connections are good, the issue is still occurring. Ghost touch still occurred when testing front panel separated from rear case. Im going to reach out to ifixit.
von
Yeah that's definitely a defective display.
von
Glad you were able to narrow that out, I hope you were able to get a new one, and install it successfully.
von
My phone fell and cracked and has been pressing random things or just not pressing at all if I fix my screen will it go back to normal or ?
Bewertung 0
This May be caused by the replacement display being faulty. i’d suggest taking it back to the repair shop and getting them to do another repair on it, if you have a screen protecter installed on the phone it may be the problem as it may have air, dirt and/or dust inside, some cheap protectors are often crappy.
If it didn’t cost much to fix the phone, then thats most likely to be exactly why its happening. So try getting it replaced at another repair shop.
I hope this info helps you! :-)
Bewertung 0
Antwort hinzufügen
Brandan Chase wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 9,476
