Zum Hauptinhalt wechseln
Mid 2010 Modell A1278 / 2,4 oder 2,66 GHz Core 2 Duo Prozessor
787 Fragen Alle anzeigen
Software for transferring data between replacing hard drives
I am going to put in a new hard drive but i do not know how to get the info for my old hard drive to the new one. I thought i might have seen it on the sight but now i cant seem to find it. When i transfer the data will all my downloaded applications go with it thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
You'll need a external hard drive adapter or enclosure to hook the new drive up to and format it, then use SuperDuper to clone it>http://www.shirt-pocket.com/SuperDuper/S...
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
when you say a external hard drive adapter, a external hard drive? and then copy the current drive in my computer to the the external one using SuperDuper then instal the new hard drive and the sync superduper?
von
You have to have a way to talk to the new hard drive and at the same time use the current drive. This can be done by using a adapter such as this one: http://eshop.macsales.com/item/Newer%20T...
or an external enclosure to put the new drive in, such as this one: [verlinktes Produkt fehlt oder ist deaktiviert: IF107-097-1]
If you use a firewire drive you can also boot from it.
von
Antwort hinzufügen
eweirick wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 1,023
