#1 If this only happens when the toothbrush is on, the pressure sensor plate doesn’t get a connection.
It’s a a little metal spring with two contacts pressing against the motor housing and the contact opens if too much pressure is applied.
Try cleaning these contacts and the opposing area if they still visibly connect. If they are bent, you might have to take apart the whole thing to straighten them.
#2 I had a similar problem where the red light came on even with the toothbrush off, completely draining the battery over night.
Opening it up, it seemed that the metal spring created a short between the upper frame and the battery.
Wrapping the spring in some duct tape seems to have fixed that issue.
After the problem came back for me after a while, I took a closer look at the toothbrush.
The reason for the LED lighting up is actually a short between the metal cage and the feed wires for the LED.
These were bent into the direction of the cage in my case.
Bending the wires up now permanently fixed the problem
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
0
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
1 Kommentar
I also have a similar problem, as soon as I click on the power button the available one does not turn on but the red light turns on. I opened the device but I don't quite understand what to do. Indeed now I noticed that if I click power the device does not turn on and not even the red light. Can someone help me?
von Gavino Peluso
