Im Juni 2017 brachte Apple die Neuausgabe vom 13" MacBook Air heraus. Es erhielt den neueren Broadwell Intel Core i5 Prozessor, die Leistung und Akkulaufzeit stieg dadurch etwas an.
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
2 Kommentare:
What is the color of the MagSafe charger Green or Amber?
you may have either I/O board issues, Charger issues, or Logic Board issues, is there any known liquid damage at all?
if there isn't, you should take it to the apple store, if there is there you should get the board repair outside of apple as they will hit you with $750 repair,
Board repair we do for $150-$450 depending on how much damage,
I would also review this Apple T/N to make sure the MagSafe charger is in good shape and the connectors are clean and healthy: Apple Portables: Troubleshooting MagSafe adapters
von Dan
von Juan
