Zum Hauptinhalt wechseln
The Nokia N8 is the first device to run on the Symbian^3 mobile operating system and Nokia's flagship device of 2010.
51 Fragen Alle anzeigen
How to switch off red LED during video recording in Nokia N8?
During Video recording the red LED on the side of the flash in Nokia N8 lights up which is annoying if you are facing the camera.
There is no option to disable the red LED. How should I disable it
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
5 Antworten
Gewählte Lösung
I believe that this is done through the settings menu. Go to Camera Settings and Turn of the Macro Option. I beleive that your setting allow you to turn it to automatic, this would turn the LED on during darkness only. Here is a great place to learn more about your N8. Good Luck to you...
War diese Antwort hilfreich?
Bewertung 3
I'm pretty sure thats so people know you are recording so you are not recording against their will. My Nokia N900 has the same thing.
Bewertung 1
As far as i know that option is disabled in some countries for privacy protection reasons. If you dont have the turn off option in the menu you simply cant do it. Same goes for the "click" sound when you take a picture.
Bewertung 1
record a video in close-up mode the red led will not light up, if it still does then zoom in and zoom out 2 or three times it will turn off.
Hope it helps you
Bewertung 0
1 Kommentar:
zoom out zoom in
or
close up doesnt worked for me :(
von
turn on camera with close-up , then start recording, close the obiectiv with you finger and turn max zoom then normal zoom . At my n8 it works every time
Bewertung 0
Antwort hinzufügen
smulam2002 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 10,657
