Zum Hauptinhalt wechseln
The SKIL 4235 Jigsaw is a handheld power tool capable of cutting thin material such as plywood or plastic in a simple or complex planar design. The tool uses 120V AC input such as a household wall socket, to power a small blade, which can be dangerous if used incorrectly. Please consult the owners' manual for safety reminders.
Replacement part for holding blade onto saw
Blade attachment collar
My saw no longer holds blades tightly. The "key" just keeps turning in the "collar". The threads on either the key or inside the collar must be worn or damaged. Can I remove and replace the "collar" device? Removal instructions would be helpful.
Dennis
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare:
@fern_dock69 your saw is a SKIL 4235 Jigsaw?
von
I also have this problem. Any suggestions for a quick fix?
von
Einen Kommentar hinzufügen
1 Antwort
Hi @Glenna L Baisden
Here’s a link to the parts for a Skil 4235.
The part number for the blade retainer (part #54 on diagram) is 2610346348.
Search online using the part number only to find suppliers that suit you best.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
I am trying to locate a used foot (base) for a Skil jigsaw 4235. I only need that part.
Please advise where I can purchase that part.
Thanks,
Karen B.
P.S. The part number is:
2610908799
von
@karenb716
Search for the part number i.e. 2610908799 to find suppliers that suit you best. There seems to be a few suppliers that have them
von
Antwort hinzufügen
Dennis Kerrigan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 20
Letzte 30 Tage: 72
Insgesamt: 1,591
