Zum Hauptinhalt wechseln
Acer Iconia A3 is a 10.1" Android 4.2 Jelly Bean tablet powered by a quad-core Mediatek processor.
11 Fragen Alle anzeigen
Front glass undamaged, when screen turned on I see cracks
I have just recently sat on my Acer Iconia Tab 10 A3-A40. There are no scratches on the front glass, if I run my fingers over it, I do not feel anything.
When I turn on the screen, it shows cracks over black background, touch is not working.
Can someone please help me find what parts I need to buy? I am unsure, but I believe I need to buy a LCD screen with digitizer. Or can I buy only LCD screen and re-use the digitizer?
thank you for your help guys!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
It seems that those are all the symptoms of a cracked LCD, so you would only need a LCD, and you could most likely reuse the digitizer. Hope that helps!
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Thank you Reed! I will order an LCD and try to fix it.
von
@peterslo No problem! I'm glad I could be of assistance! Good luck with the repair!
von
Antwort hinzufügen
peter wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 182
