iPhone 7 Plus home button not responding after screen replacement
Hello.
I replaced a screen and LCD for an iPhone 7 Plus and it seems as if the home button is not responsive.
When it's asleep I hit the home button and it doesn't wake. When I hit the power button it wakes up. Am I missing something or doing something wrong?
I'm using an iPhone 6 Plus and it wakes up when I hit the home button.
It stays showing this.
Ist dies eine gute Frage?
4 Kommentare
Did you also replace the touch ID button with a new one or the same original one? Also, did you make sure you attached the button cable correctly when you replaced it?
von James
@kmkz I purchased a home button replacement. Is this considered the "Touch ID button"? If so than yes. I tried 2 replacement screens with original home button and new home button on both and no luck. Yes the cable at the button that connects from the home button to the LCD is snapped in correctly if that's what you're asking.
von Matthew Notes
Are both the screens from the same supplier? If so, you probably got both out of the same bad batch possibly, if you bought the screens for cheap, they could be low quality aftermarket parts.
von James
The answer is very simple- there are 5 screws and the one that goes behind the home button is shorter than the others. Do not mix the screws up and you will not have an issue. Hope that helps ya'll
von mazzolagregory
