Zum Hauptinhalt wechseln
Die Apple Watch Series 1 ist eine Überarbeitung der ursprünglichen Apple Watch, sie wurde am 7. September 2016 angekündigt. Die meisten Teile sind die gleichen wie bei der Series 2
Can you replace a swollen battery in my Apple Watch?
My Apple Watch screen lifted and come to find out it is due to the battery overheating and it swelled. Just curious if it could be fixed?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Yes, It can be fixed! Given the fact the screen is already pulled away a bit it should make doing this your self much easier. Are you up to it?
To help you, review this vid of Alex opening a Series 2, it's the same for your Series 1 (the Original Apple Watch is a bit different) How to Replace the Battery on an Apple Watch Series 2 and you might want to review the Original Apple Watch guides while slightly different the same techniques are needed: Apple Watch Akku austauschen I'm sure you can forgo the iOpener as the display is already lifted. You will need to fully clean the surfaces of the old gasket both the case and the display. And do be gentle! The parts can be easily damaged.
Here's the needed parts:
38mm Watch
42mm Watch
Just take your time and don't forget to breathe ;-}
Replace the force touch sensor and adhesive that fits between the display and rear case of specific models of the Apple Watch. Fits 42mm Series 2 and Series 3 Cellular models. Model numbers A1758, A1817, A1861, A1891, and A1892. Bild
Produkt
Apple Watch (42 mm Series 2 & Series 3 Cellular) Force Touch Sensor Adhesive Gasket
$14.99
Replace the force touch sensor and adhesive that fits between the display and rear case of specific models of the Apple Watch. Fits 38mm Series 2 and Series 3 Cellular models. Model numbers A1757, A1816, A1860, A1889, and A1890. Bild
Produkt
Apple Watch (38 mm Series 2 & Series 3 Cellular) Force Touch Sensor Adhesive Gasket
$14.99
Replacement battery for the 38 mm Series 2 Apple Watch models A1757 and A1816. 3.77 Volts (V). Battery model A1760. Bild
Produkt
Apple Watch (38 mm Series 2) Battery
$16.99
Replace a battery compatible with Apple Watch 42 mm Series 2 Models A1758 and A1817 smartwatches. Bild
Produkt
Apple Watch (42 mm Series 2) Battery
$16.99
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Can you explain why you need a replacement gasket as opposed to just buying a replacement adhesive strip? Thanks!
von
Only because you often damage it in the process of taking the display assembly off.
von
Apple has extended its service coverage for Apple Watch (1st gen) models experiencing expanded/swollen battery problems to three years, covering customers for service for an additional two years beyond the complimentary 1-year Limited Warranty that it provides with the device.
https://9to5mac.com/2017/04/28/apple-wat...
They will fix the watch for free. You need to call Apple; and provide this information about the extended coverage for series 1 only.
Bewertung 1
2 Kommentare:
Can you give me a link to this? I went to apple service center today and they said the warranty for swollen battery is two years only. My watch broke after 2 years and a half. they want me to pay $250 for a new watch.
von
I called the Apple store before went in and was told they'd replace the battery for $79. But when I got there, a friendly Genius Bar genius told me it would cost much more. So... guess that isn't a thing anymore.
von
Antwort hinzufügen
Catie Mullinax wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 27
Insgesamt: 15,516
