Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Die Xbox Spielkonsole der dritten Generation von Microsoft kam am 22. November 2013 auf den Markt;
555 Fragen Alle anzeigen
Lightning strike on the HDMI port
My Xbox had the cable box video set up on it and lightning hit and everything went out and now the picture on my Xbox doesn't look right and I don't know how to fix it . It still works and everything but the picture is small any help would be great if anybody has any ideas
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
Nintendo Switch Kits
Eine schnelle Lösung, um wieder ins Spiel zu kommen
Switch Kits kaufen
Switch Kits kaufen
3 Antworten
Gewählte Lösung
Is it stuck in low resolution mode? If yes it's probably a HDMI chip / circuit fault. A reputable console repair store can get that fixed for you. Might be one available locally.
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
Try unplugging everything including the plugin brick (if you are using one) for a minute or two then pulg it back in. Also unplug any usb drives and take out any disk beforehand.
Bewertung 1
Kommentare:
Not a foolproof plan but that’s what works with some things.
von
Are your devices plugged into a surge protector or a power strip? Surge will be bulky and power strip a thin bar with outlets. If it took a lightning surge without surge protection it's going to be VERY difficult to identify the problem unless you've got professional training in electronic repair. If there wasn't surge protection you're “lucky" it even powers on at all to attempt to fix it. Unless you have pro skills I only see 2 options, 1 take it to a pro 2 replace the entire system. Unfortunately either way you pay out of pocket. New console would probably be your best bet. Even if a professional gets it working there's 0 guarantee that other parts won't soon follow suit of the original damaged components. If other parts took damage but not enough to fry them than providing full power to the system will only compromise them. Sorry I can't offer better advice
Bewertung 1
Antwort hinzufügen
Chuckwaqon wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 13
Letzten 30 Tage: 63
Insgesamt: 741
