Zum Hauptinhalt wechseln
The Kindle Touch (D01200) is 4th generation of Kindle e-readers produced by Amazon. There is Wi-Fi or Wi-Fi/3G capability, all uploads are done by USB cable. It has 4 GB of storage and two months of battery life.
The port to charge my kindle is wobbly so I am having problems it.
When I insert the cable I have wiggle it around for the yellow light to come on and it stops registering the cord unless i hold it in place. How do I fix this?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
Thanks. I finally got my new cord and everything is fine. I really thought it was the port itself. This was much easier than trying to get the port fixed.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Get a new charger!! Sometimes when you have a charging cable in the same position for a while, it gets a bit worn down. Unless you get a different charger, it will only charge in a certain position.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Donna Zamkotowich wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 557
