I have this same problem with my early '09 MacBook Pro 17" and new battery.
Although it ran on the AC adapter fine, my 2+ year old battery was not charging, and the magsafe charge indicator never showed amber before, during or after boot up. After replacing the battery the problem persisted, even after resetting SMC and PRAM multiple times. The new battery has gradually gone from showing 100% to 0% charge., and the macOS status shows "battery is not charging".
Do you thing the after market battery is the issue?
CoconutBattery Info
MacBookPro5,2 \ Mfg 2009-2-23 \ OSX El Capitan
Current Charge 46mAh
Full Chg Cap 16500 mAh \ bar meter shows 0.3%
Design Cap = 16000mAh \ bar meter shows 100%
mfg date 2018-12-23 \ cycle count 80
macOS Batt status Good \ Batt temp 21.1 C
Charging with 0 Watts \ Power Adapter Connected
Battery Info:
MFG Simplo \ Age 61days \ Load cycles 80
macOS batt stat Good \ Batt temp 21.1C
Battery failure none \ Poweradapter 85Watts
Thanks, MJ
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
0
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
1 Kommentar
Does the MagSafe charger stay Green or does it get to Amber?
Download this app: CoconutBattery take a snapshot of the main window as well as the Battery info window. Paste them here for us to see.
Bilder zu einer vorhandenen Frage hinzufügen
von Dan
