Zum Hauptinhalt wechseln
The Chevrolet Cavalier is a compact automobile produced from 1982 to 2005 by General Motors.
Remove Bench Back Seat
How do I remove the bench backseat?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Force the lower end of the bench seat back toward the trunk to release to clips at the bottom of seat and lift out--You will find either clips or screws at the lower end of the upper portion of seat--release these and lift upper section of seat should release from locking clips allowing removal of upper section
War diese Antwort hilfreich?
Bewertung 7
7 Kommentare:
am amazed by the things you know! ;-)
von
ah shucks ma'am
von
How do you get the clips to reatatch thanks
von
Does anyone know what these locking clips are called? They are broken and I cannot put a car seat in my car because of it. I need to order new ones ASAP
von
i cannot seem to locate any hardware on mine. looks like its a pin on both sides, and this runs straight into the seat. I've removed the lower seat, cannot get the fold down part out.
von
2 weitere Kommentare anzeigen
if your release strap on your upper backseat is broke, stick a pair of needle nose pliers in the opening right in the middle of the upper backseat grab the latch and pull. now just go do it.....
Bewertung 0
I took the seat out and broke the clips because I didnt read anything first. Like a idiot. What is the best way to replace the clips? Or just buy a new backseat?
Bewertung 0
Antwort hinzufügen
Mark wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 37
Insgesamt: 22,062
