Zum Hauptinhalt wechseln
LTE Version des iPad Mini 2. Angekündigt am 22. Oktober und erschienen am 13. November 2013. Das iPad mini 2 bringt die Pixelanzahl des iPad Air auf nur 7,9 Zoll unter.
Is this a battery leak?
I opened an iPad Mini earlier to replace the screen and found a shiny coating on one end of the battery. Does this look like a battery leak?
The coating is already dry and feels fairly smooth. It only appears along the top of the battery along the edge that's exposed under the LCD shield plate. There's no sign of fluid below the battery or elsewhere in the iPad. This device has been repaired before.
If it's not from the battery, is there anything else in there that might leak? The LCD looks fine. There were no reported battery issues, either.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
That does not look right.. Looks like something melted at the bottom of the battery.
War diese Antwort hilfreich?
Bewertung 0
Yes, you will probably have to replace the battery and any components that have been damaged by the leakage.
It looks at though the battery acid has dried up.
Bewertung 0
Antwort hinzufügen
Ket wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 1,180
