Zum Hauptinhalt wechseln
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
262 Fragen Alle anzeigen
Water damage few years ago, loads menu but software won’t load
Ok, so a while back my DSi got submerged in water about halfway and I didn’t do anything about it. I kept it for a few years and now it can apparently turn on, charge, load the menu, turn on camera, shuffle images on top screen, produce sound, but whenever I click on any application/software (like the settings or a game) it gives me an error. No error is specified so I’m not sure what to do. By the way, it can recognize games and the screen works perfectly fine. It’s just whenever I tap on any software the bottom screen gives me an error message.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
When water is allowed to dry, it leaves residue that can oxidize circuits or cause shorts. What I would do is open the DSi and look at the board and bottom screen. Any where you see white spots, use 91% alcohol with a q-tip and try to clean it off. If you see rust, it may be too late but see if you can remove it as well. Make sure It is completely dry before reassembling.
It is very important to open and clean any board when exposed to water immediately to prevent damage to circuits. Good luck.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Alright, thanks so much. I’ll be sure to do that.
von
Antwort hinzufügen
Allen Merkel wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 73
