Zum Hauptinhalt wechseln
Repair guides and support for the EOS 70D, a DSLR camera released by Canon in 2013. This camera can be identified by the model number DS126411.
66 Fragen Alle anzeigen
Green lines across my images
I purchased a Canon 70D over eBay and on all the manual settings, the images have two solid green lines across them. This could indicate a possible sensor problem, however, if I shoot on Automatic the lines are not there - could this be possible?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Had a similar problem with a 5D MKIII, replaced the Sensor Ass'y, Main PCB & Mirror Drive PCB with test parts and didn't fix it, figured Main PCB was corrupted so downloaded and installed Magic Lantern (only on the memory card) ran the test's it comes with and fixed !!!
War diese Antwort hilfreich?
Bewertung 0
Change the aspect ratio of raw images to 3:2 or the default that it came with and you can crop it latter
Bewertung 0
Antwort hinzufügen
Nell Delport wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 1,065
