Zum Hauptinhalt wechseln
Der Game Boy kam am 21. April 1989 in Japan auf den Markt, dann am 31. Juli 1989 in Nordamerika und schließlich am 28. September 1990 in Europa. Er ist erkennbar an einem großen grauen Gehäuse und der Modellnummer DMG-01
71 Fragen Alle anzeigen
Cleaned battery corrosion, but A and B buttons don't work
Hi! I came upon my brother's old original Gameboy yesterday. It had battery corrosion from years ago; I don't know much at all about electronics but have fixed a few toys with battery corrosion before. Gameboy wouldn't turn on; I took it apart and cleaned all the corrosion I could, first a little with baking soda/water and then with vinegar....Turns on now and everything works, EXCEPT for the A and B buttons, obviously making gameplay impossible...Links to pics below: is there anything I can do to get it working/what part is keeping it from working? I realize it's not completely clean but don't want to spend more time on if I've broken something beyond repair (some of the green...plastic? started "melting" off on the back side....was vinegar not supposed to touch that....?) If it can't be fixed, I guess we'll at least have a very cool Super Mario World 1-1 music player, haha. Thanks!
[IMG]http://i67.tinypic.com/35mozmg.jpg[/IMG] [IMG]http://i67.tinypic.com/1054jsw.jpg[/IMG] [IMG]http://i65.tinypic.com/2ldj1w2.jpg[/IMG] [IMG]http://i66.tinypic.com/ay0npe.jpg[/IMG] [IMG]http://i68.tinypic.com/kcxcah.jpg[/IMG]
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi!
Looks like you used the wrong type of alcohol, the vinegar seems to have corroded the electrical traces inside the mother board. You should have used Isopropyl Alcohol.
Now, about the repair: I've seen people fixing this kind of problem by basically bridging the corroded area with a cable: What you have to do is to is to scrub the protective green layer off the board (before the corroded area) on the side where you can see the traces (pics 2 to 4) until you get to the conductive trace itself, solder a wire there and where the corroded are ends.
This is not 100% guaranteed fix, but if you feel confident it could save yourself the hustle of buying a new board.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Hi @alexniculescu ,
"Rubbing" alcohol will do if you cannot get anything better but you should really use IPA 90%+ (Isopropyl Alcohol - available at most pharmacies) to clean off corrosion and to disperse liquids when cleaning electronics.
Rubbing alcohol is usually <70% IPA and can contain scents. It is not as effective as the purer IPA. Check the label on the bottle to verify the amount of IPA and "other" ingredients before using rubbing alcohol.
Cheers
von
Hi @jayeff
Sorry, I meant the same thing as you mention, just did not remember the English name...
von
Antwort hinzufügen
clari wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 16
Insgesamt: 1,522
