Zum Hauptinhalt wechseln
Dritte iPad Generation, 4G fähig, Modellnummer A1430, erhältlich seit dem 16. März 2012. Die Reparatur erfordert Hitzezufuhr und vorsichtiges Hebeln.
106 Fragen Alle anzeigen
Why my iPad doesn't go past Apple logo?
I have a A1430 WIFI + CELLULAR iPad which was running completely fine. However, it start discharging completely when the battery came down to 30% . Then , while plugging in to charge, first the red battery comes on followed by the Apple logo & keep going on loop. Doesn't charge or go beyond the Apple logo. Really frustrated & kindly requesting for suggestions. Pleasure
https://youtu.be/xx9VM6GMcnM
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Your problem appears to be a dead battery. It doesn't take a charge and it's not charged enough to boot the iPad. Considering the age of the device, this is completely normal. You can change it yourself, just check out this repair guide to see if your comfortable with all the steps.
War diese Antwort hilfreich?
Bewertung 2
Probably a dead battery, you should get it replaced.
I'm not sure if it could be a logic board issue because something similar is happening to my iPhone 5s.
Bewertung 0
Antwort hinzufügen
Robin Kalam wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 78
