Zum Hauptinhalt wechseln
Reparaturanleitungen, Demontage- und Fehlerdiagnose-Informationen für die 4. Generation des Apple iPad mit GSM 4G LTE-Mobilfunknetz (AT&T), erhältlich mit 16, 32, 64 oder 128 GB Speicherplatz. Veröffentlicht im November 2012. Identifiziert durch die Modellnummer A1459.
Display wont turn on, iTunes says its powered
Hi,
Got an iPad here that the customer said its just not powering on. I plugged it into the PC and opened 3uTools and it wasn't turned on. I charged it for more than 24 hours waiting for life but there was none. I changed the charging port and still made no difference. So I tried a new LCD whilst it showed the Apple logo (White) it went back off after it flashed about 3 times. I have since changed the battery too and It seemed to have more power. I was able to reflash the iOS thinking it could just be a bad software glitch and it seemed to have worked. I can setup the iPad as new and seemed ok.
But after the setup when the screen timeout kicks in I cannot get it to turn the display back on. iTunes and 3uTools says its turned on but there is no display. I've tried 2 new screens now and its still the same.
Any Ideas?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
I have tried 2 new LCD's and still the same affect.
It just doesn't want to come off standby mode.
von
There is nothing on to see when I shine a light on the LCD. Totally black
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Have you tried shining a bright flashlight on the "black" screen when it should be on? I am wondering if you don't have a backlight issue. It might be partially working but not capable of handling an extended on-time.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
von
I am not talking about the LCD's but the backlight circuit on the logic board. If multiple LCD's don't work, then the problem is probably on the logic board. Have you tried shining a bright light?
von
Antwort hinzufügen
Jaymie wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 23
Insgesamt: 440
