Zum Hauptinhalt wechseln
Guides for the LTE version of the iPad Mini 4—model A1550. Announced on September 9, 2015, the iPad Mini 4 is the successor to the iPad Mini 3.
20 Fragen Alle anzeigen
iPad automatic shutdown by no reason
When I use my iPad like normally but sometime it alway shutdown automatic and cannot turn on .
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
This has been an issue recently, it is likely due to an old and degraded battery. This can occur when the device pulls too much voltage from a battery that cannot sustain it, so it shuts down to protect itself. Here is a part for replacement and here is a guide.
Replace a model A1546 battery compatible with iPad mini 4th generation.
3.82 Volts (V). 19.32 Watt Hours (Wh). Bild
Produkt
iPad mini 4 Battery
$34.99
War diese Antwort hilfreich?
Bewertung 1
11 Kommentare:
Thank you for your advice.
von
But sir it the new iPad and then just open from the box.
von
@reedcrosby04
von
If it's a brand new device, then bring it back for a replacement.
von
6 weitere Kommentare anzeigen
Antwort hinzufügen
Eden wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 1,319
