Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Das zweite Smartphone des gleichnamigen Unternehmens. Es erschien erstmals im Dezember 2015. Modellnummer: FP2-XCVR
64 Fragen Alle anzeigen
Can't call or send texts, Radio stuck on off
Hello
I've had a problem where I can't use my sim cards.
At first I thought my phone was stuck on airplane mode but that was not the case.
It seems to be a network issue as both my sim cards are affected. And my phone simply states no network.
I can't seem to switch from 4G to 3G or 2G for one. I click the option but it remains fixed on 4G.
When I make phone calls there's a notice that says Radio Off and so the call does not go through. Hence I can't even call fairphone
The one number I could call led to a prompt.
I called the number to try and have the radio switched on but like the 4G option the radio remained fixed on off.
Also my WiFi works fine it's only the mobile network.
Has anyone had a similar issue? Please help
Ist dies eine gute Frage?
Bewertung 5
Kommentare:
Having the same problem radio off and airplane mode radio off I know it's not in airplane mode I know how to turn the radio off I have hard reset phone still no luck I don't know this one. I am able to use Wi-Fi internet.
von
Same problem here How to recover that plz help
von
Yes please help us same issue with me I'm using redmi note 4
von
Einen Kommentar hinzufügen
SPAR DIR DAS UPGRADE
Mach dein iPhone so gut wie neu mit unseren Fix Kits.
Jetzt entdecken
Jetzt entdecken
4 Antworten
Hilfreichste Antwort
Hi @dkwene ,
Try starting the phone in safe mode to see if perhaps a downloaded app is causing the problem.
Take heed of the "Please Note" near the top of the page.
Update (03/01/2018)
Hi @dkwene ,
Try inserting a different known working SIM card which uses the same network provider as your SIM cards and see if it works OK. Check if your card(s) work in a different known working same network phone. Basically swap SIM cards between two phones.
If it still doesn't work try a factory reset and then check if it works OK.
Be aware that a factory reset will erase all your data and downloaded apps, it will restore the phone to its' factory default condition. It will be like when you first bought it.
Before you perform a factory reset, backup the phone first using the phone's backup feature. That way if the reset solves the problem you can restore the phone, with all your data etc, from the backup that you made, using the phone's restore feature.
If it still fails after the factory reset, then the phone is faulty.
As it is new, consult the manufacturer's warranty statement, usually found with the documentation that came with the phone or in the User Guide as to what you have to do to make a claim for a manufacturer's warranty repair, replacement or refund
War diese Antwort hilfreich?
Bewertung 1
Kommentare:
Hi jayeff I started it on safe mode and it still has the same issue. Might you know a way to turn on the radio?
von
Pull Sims out and clean them off with a Qtip
Then blow any dust out of where the sims go
Try that first
I once had the same problem turned out to be lint in the Sim Card Tray
Bewertung 0
Kommentare:
Still no luck, I've tried switching round the sims cards and also just having one some card in. It's a new phone I've had it for about a week. I've attached an image showing the service status which is what I'm having a problem with the most. Still unsure how to switch on the radio
von
If I update my android version from android 8 to 9 does this process will solve the problem.
What do you think bro if you read message me in
supermanbhardvaj2@gmail.com
von
Did you turn on your radio while you were on call before this problem happened?
I tried turning on the radio while on call and it gave me this message, “Please do not turn on fm radio during a phone call".
I guess it causes some problems that's why instead of the usual message of “Cannot start radio” or “Can't start the service” it displayed this message “do not turn on “.
Bewertung 0
I just experienced it now…..but then I just restarted my phone..and the network came back
Bewertung 0
Antwort hinzufügen
Dianne K wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 21
Letzten 7 Tage: 107
Letzten 30 Tage: 586
Insgesamt: 6,864
