Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
iPad Air Wi-Fi und Mobilversion, Modellnummer A1475. Verfügbar in Space Gray oder Silber, Speicheroptionen 16/32/64/128 GB.
119 Fragen Alle anzeigen
Can I use an A1474 main board as a replacement?
A1475 logic boards are quite expensive, while A1474 boards seem much more readily available. From my uneducated perspective, the major difference between the two is that the A1475 has a spot to hook up the LTE antennas, and I'm sure some circuitry to process it.
Can I slap an A1474 board in there and just not hook up the LTE antennas, and use the unit as a Wifi only Ipad? The reason the board is bad in the first place is the power management chip is bad (confirmed by replacing the battery and still not being able to charge).
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
SPAR DIR DAS UPGRADE
Mach dein iPhone so gut wie neu mit unseren Fix Kits.
Jetzt entdecken
Jetzt entdecken
1 Antwort
Yes, you can always just not connect the LTE antennas. But then, you'd just have no LTE at all, and your frame would say you had a A1475 iPad, so then you blow all chances of ever doing a Trade-In, and selling it would be a hassle to explain. But if that does not bother you, yes you can just not connect the LTE systems and use it as a WiFi iPad Air.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Mark Herter wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 8
Insgesamt: 206
