A very unique freezer problem
I recently picked up a freight damaged saturn commercial freezer. It was dropped by the Looks of it and the heat exchanger had broken free of the Compressor. After changing the oil (polyoster 32) replacing the dryer, and reattaching all connections, I evacuated the system and recharged it with r404a. It now cools down to 18 but it Should get down to -10. Evaporator is functioning Fine and It's a new unit so all coils are clean. Not Sure Where to go from here. Any help would be appreciated.
Ist dies eine gute Frage?
9 Kommentare
Hi @yaslana ,
What is the model number?
Check if it has a thermistor or thermostat type sensor that "tells' the control board to stop the compressor as the temp has been reached. Perhaps it is faulty.
If you look up 'Saturn (insert model number) parts' it should tell you what is there in the way of thermistors etc.
von jayeff
It's a saturn stm23f. The Compressor runs constantly but will Not reach proper temp. Everything seems to be functioning as it should.
von Loren
Refrigerant is charged at 50psi On the suction side.
von Loren
Hi @yaslana ,
Just verifying that the evap fan is working OK?
How 'cold' does the evap unit feel?
Be careful as you could literally stick to it with bare skin if it is OK. It should be icy cold. Use cotton gloves.
How long has it been running?
Sometimes it can take 12-24 hours to get to correct temp when starting from ambient.
Try placing a thermometer inside to verify that the display temp is correct.
Are the door seals OK and sealing tightly that there is no cold air escaping?
Just some thoughts.
von jayeff
Evap fan is Working. Digital temp verified with thermoelectric probe. I relieve some of the refrigerant and temp dropped to 14 at last check.
von Loren
4 weitere Kommentare anzeigen
