Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
2683 Fragen Alle anzeigen
How can I test a replacement battery to be 100% sure it's good?
I'm about to replace a battery for a client who lives out of town. In the past, I've replaced batteries that started malfunctioning within a couple days, but since this client can't easily come back for a replacement, I want to make 100% sure the battery's good before sending them on their way.
My plan is currently to plug in a battery, turn on the device, use the Battery Life app and do a stress test with video streaming. If it passes the tests, is this enough to be sure the battery is good? Are there any other tests that can make sure this battery won't start acting up in a couple days?
Thanks.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Your testing sounds solid. However, batteries are a curious beast due to their chemical nature. The best way to insure you have good batteries is to stick with quality suppliers. If you have had issues in the past with a certain supplier, you may want to reconsider things and find one who has a very high quality rate.
War diese Antwort hilfreich?
Bewertung 4
1 Kommentar:
Thanks for the reassurance. I'd still rather do the 2-minute test & deal with returns than spend an extra $10 per battery to avoid it. If you do the math, 2 mins x 30 x $10 = $600/hour. When I'm doing the annoying tests, I'll just remind myself that I'm getting paid $600/hour to do it.
von
Antwort hinzufügen
fdsajky675 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 78
